跳转到主内容
Dell Chromebook 13-7310 IO Board Replacement
你所需要的
  1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 IO Board Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 IO Board Replacement, Battery: 步骤 3 中的图像 1,1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 IO Board Replacement: 步骤 4 中的图像 1,1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 IO Board Replacement: 步骤 5 中的图像 1,1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 IO Board Replacement, IO Board: 步骤 6 中的图像 1,1
    • Remove the single 2mm screw securing the IO board to the laptop.
  7. Dell Chromebook 13-7310 IO Board Replacement: 步骤 7 中的图像 1,1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  8. Dell Chromebook 13-7310 IO Board Replacement: 步骤 8 中的图像 1,1
    • Remove the IO board.
结论
Damon
于11/01/18注册
181 声望
创作了2篇指南
团队
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 320
