跳转到主内容
Dell Chromebook 13-7310 Cooling Fan Replacement
你所需要的
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,2 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 2,2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: 步骤 4 中的图像 1,2 Dell Chromebook 13-7310 Cooling Fan Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
结论
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 477
