跳转到主内容
Dell Chromebook 13-7310 Battery Replacement
你所需要的
  1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Chromebook 13-7310 Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Battery Replacement: 步骤 5 中的图像 1,1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
结论
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 1,255
