跳转到主内容
加入维修社区 - 创建账户
Dell Chromebook 11-3120 Speakers Replacement
你所需要的
  1. Dell Chromebook 11-3120 Speakers Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Chromebook 11-3120 Speakers Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Speakers Replacement: 步骤 2 中的图像 1,2 Dell Chromebook 11-3120 Speakers Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Speakers Replacement, Battery: 步骤 3 中的图像 1,2 Dell Chromebook 11-3120 Speakers Replacement, Battery: 步骤 3 中的图像 2,2
    • Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
  4. Dell Chromebook 11-3120 Speakers Replacement: 步骤 4 中的图像 1,1
    • Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
    • Pull out the battery from inside the laptop.
  5. Dell Chromebook 11-3120 Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Gently remove the 4-pin connector that connects the speakers to the motherboard.
  6. Dell Chromebook 11-3120 Speakers Replacement: 步骤 6 中的图像 1,1
    • Remove the tape securing it to the plastic casing of the device.
  7. Dell Chromebook 11-3120 Speakers Replacement: 步骤 7 中的图像 1,1
    • Carefully lift out the right speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
  8. Dell Chromebook 11-3120 Speakers Replacement: 步骤 8 中的图像 1,1
    • Moving down the cable, remove the left speaker housing, which is held in place by circular rubber guides, located on both sides of the housing.
结论
另外一个人完成了本指南。
Joseph Silveira
于10/19/17注册
401 声望
创作了3篇指南
团队
UMass Dartmouth, Team S4-G1, Julie Fall 2017 UMass Dartmouth, Team S4-G1, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G1
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 542
