跳转到主内容
Dell Chromebook 11-3120 Battery Replacement
你所需要的
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: 步骤 1 中的图像 1,1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: 步骤 2 中的图像 1,2 Dell Chromebook 11-3120 Battery Replacement: 步骤 2 中的图像 2,2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: 步骤 3 中的图像 1,1
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: 步骤 4 中的图像 1,1
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
结论
Dalton D
于12/08/17注册
2,596 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 408
