跳转到主内容
Dell Chromebook 11-3120 Battery Replacement
你所需要的
  1. Dell Chromebook 11-3120 Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Chromebook 11-3120 Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Battery Replacement: 步骤 2 中的图像 1,2 Dell Chromebook 11-3120 Battery Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
  3. Dell Chromebook 11-3120 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Dell Chromebook 11-3120 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
  4. Dell Chromebook 11-3120 Battery Replacement: 步骤 4 中的图像 1,1
    • Using the pointed end of a #2 spudger, remove the connection between the battery and motherboard by slightly pulling on the wires while pushing the tiny hole down using the spudger.
    • Pull out the battery from inside the laptop.
结论
8等其他人完成本指南。
Mitchell Stevens
于10/19/17注册
406 声望
创作了2篇指南
团队
UMass Dartmouth, Team S4-G1, Julie Fall 2017 UMass Dartmouth, Team S4-G1, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 2,660
