跳转到主内容
Dell Chromebook 11 CB1C13 Fan Replacement
你所需要的
  1. Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 步骤 1 中的图像 1,3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 步骤 1 中的图像 2,3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 步骤 2 中的图像 1,3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 步骤 2 中的图像 2,3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: 步骤 2 中的图像 3,3
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. Dell Chromebook 11 CB1C13 Fan Replacement: 步骤 3 中的图像 1,3 Dell Chromebook 11 CB1C13 Fan Replacement: 步骤 3 中的图像 2,3 Dell Chromebook 11 CB1C13 Fan Replacement: 步骤 3 中的图像 3,3
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
结论
Bryan Allen
于10/20/17注册
272 声望
创作了2篇指南
团队
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 UMass Dartmouth, Team S3-G6, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G6
3 名成员
创作了7篇指南
一条评论
Ram?
Can i change the ram?
flip - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,023
