跳转到主内容
Dell Chromebook 11 3180 Touchpad Replacement
你所需要的
  1. Dell Chromebook 11 3180 Touchpad Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 5 中的图像 1,1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Touchpad Replacement, Battery: 步骤 6 中的图像 1,2 Dell Chromebook 11 3180 Touchpad Replacement, Battery: 步骤 6 中的图像 2,2
    • Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
    • You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
  7. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
  8. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Lift the battery away from the computer to remove it.
    • If there is any resistance to the battery being removed, make sure that all of the screws have been properly removed and that nothing is blocking the battery.
  9. Dell Chromebook 11 3180 Touchpad Replacement, Touchpad: 步骤 9 中的图像 1,2 Dell Chromebook 11 3180 Touchpad Replacement, Touchpad: 步骤 9 中的图像 2,2
    • Unplug the touch pad from itself by lifting up on the connector and pull out the ribbon cable.
  10. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 10 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the five 2mm and single 3mm screws. Set the screws aside and note that they are for the touch pad.
    • One screw will be slightly smaller in size than the other five.
  11. Dell Chromebook 11 3180 Touchpad Replacement: 步骤 11 中的图像 1,1
    • Lift the touch pad, with it's bracket, away from the computer to remove it.
结论
Devon Paul
于04/26/17注册
1,206 声望
创作了6篇指南
团队
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 2,116
