跳转到主内容
Dell Alienware M18x R2 Hard Drive Replacement
你所需要的
  1. Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Connector Latch: 步骤 1 中的图像 1,2 Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Connector Latch: 步骤 1 中的图像 2,2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive
    • Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
  2. Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 2 中的图像 1,1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  3. Dell Alienware M18x R2 Hard Drive Replacement, Disconnecting the Interposer: 步骤 3 中的图像 1,2 Dell Alienware M18x R2 Hard Drive Replacement, Disconnecting the Interposer: 步骤 3 中的图像 2,2
    • Disconnect the interposer from the hard drives.
  4. Dell Alienware M18x R2 Hard Drive Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the hard drive(s) and slide the hard drive(s) out of the hard-drive bracket.
  5. Dell Alienware M18x R2 Hard Drive Replacement, Placing the Hard Drive: 步骤 5 中的图像 1,1
    • Place the NEW primary hard drive (HDD 0) in the hard-drive bracket.
  6. Dell Alienware M18x R2 Hard Drive Replacement, Sliding the Hard Drives: 步骤 6 中的图像 1,1
    • If applicable, slide the secondary and tertiary hard drive(s) into the hard-drive bracket.
  7. Dell Alienware M18x R2 Hard Drive Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the screws that secure the primary hard drive (HDD 0).
  8. Dell Alienware M18x R2 Hard Drive Replacement, Connecting the Interposer: 步骤 8 中的图像 1,1
    • If applicable, replace the screws that secure the secondary hard drive (HDD 1) and tertiary hard drive (HDD 2) to the hard-drive bracket.
    • Connect the interposer to the hard drive(s).
  9. Dell Alienware M18x R2 Hard Drive Replacement, Placing the Hard-Drive Assembly: 步骤 9 中的图像 1,1
    • Place the hard-drive assembly in the computer base.
  10. Dell Alienware M18x R2 Hard Drive Replacement, Tighten the Captive Screws: 步骤 10 中的图像 1,1
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  11. Dell Alienware M18x R2 Hard Drive Replacement, Sliding the Hard-Drive Cable: 步骤 11 中的图像 1,1
    • Slide the hard-drive cable into the connector on the system board and press down on the connector latch to secure the cable.
结论
Terrence15
于12/18/17注册
78,592 声望
创作了441篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,982篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 825
