跳转到主内容
Dell Alienware M18x R2 Display Assembly Replacement
你所需要的
  1. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the Video-Card Connector Cable: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Disconnect and peel off the video-card connector cable from the connectors on the system board.
  2. Dell Alienware M18x R2 Display Assembly Replacement, Pull the Pull-Tab: 步骤 2 中的图像 1,1
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  3. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the LED Logo Board Cable: 步骤 3 中的图像 1,1
    • Disconnect the LED-logo board cable from the connector on the system board.
  4. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Close the display and turn the computer over.
    • Remove the screws that secure the display assembly on the computer base.
  5. Dell Alienware M18x R2 Display Assembly Replacement, Note the Routing: 步骤 5 中的图像 1,1
    • Disconnect the antenna cables from the connectors on the Mini-Card.
    • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
    • Turn the computer over and open the display.
    • Note the routing of the display cable and LED-logo board cable, and then remove the cables from the routing guides on the palm-rest assembly.
  6. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: 步骤 7 中的图像 1,1
    • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
  7. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Antenna Cables: 步骤 8 中的图像 1,1
    • Gently slide out the antenna cables through the slot on the computer base.
  8. Dell Alienware M18x R2 Display Assembly Replacement, Moving the Display: 步骤 9 中的图像 1,1
    • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
  9. Dell Alienware M18x R2 Display Assembly Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
    • Route the display cable and LED-logo board cable through the routing guides on the palm-rest assembly.
  10. Dell Alienware M18x R2 Display Assembly Replacement, Connecting the Display Cable: 步骤 12 中的图像 1,1
    • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
  11. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Cables: 步骤 13 中的图像 1,1
    • Slide the Mini-Card antenna cables through the slot on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
结论
另外一个人完成了本指南。
Terrence15
于12/18/17注册
78,592 声望
创作了441篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,982篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 933
