跳转到主内容
Dell Alienware M18x Memory Modules Replacement
你所需要的
  1. Dell Alienware M18x Memory Modules Replacement, Popping up the Memory Module: 步骤 1 中的图像 1,3 Dell Alienware M18x Memory Modules Replacement, Popping up the Memory Module: 步骤 1 中的图像 2,3 Dell Alienware M18x Memory Modules Replacement, Popping up the Memory Module: 步骤 1 中的图像 3,3
    • Follow the instructions in Before You Begin.
    • CAUTION: To prevent damage to the memory -module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Alienware M18x Memory Modules Replacement, Align the Notch: 步骤 2 中的图像 1,2 Dell Alienware M18x Memory Modules Replacement, Align the Notch: 步骤 2 中的图像 2,2
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  3. Dell Alienware M18x Memory Modules Replacement, Sliding the Memory Module: 步骤 3 中的图像 1,1
    • Slide the memory module into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
结论
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 148
