简介
In this guide, we will show you how to remove and replace the Hard Drive.
你所需要的
Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
Loosen the four captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the primary hard drive (HDD 0) and lift the hard drive out of the hard -drive bracket.
Remove the four screws that secure the secondary hard drive (HDD 1) and slide the hard drive out of the hard-drive bracket.
If applicable, slide the secondary hard drive into the hard-drive bracket.
If applicable, replace the four screws that secure the secondary hard drive (HDD 1) to the hard-drive bracket.
Connect the interposer to the hard drives.
Tighten the four captive screws that secure the hard-drive assembly to the computer base.
Connect the hard-drive cable to the connector on the system board and press down on the connector latch to secure the cable.
