跳转到主内容
Dell Alienware M17x R3 Memory Modules Replacement
你所需要的
  1. Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Modules: 步骤 1 中的图像 1,2 Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Modules: 步骤 1 中的图像 2,2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Remove the three screws that secure the memory-module cover to the palm rest assembly.
  2. Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: 步骤 2 中的图像 1,3 Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: 步骤 2 中的图像 2,3 Dell Alienware M17x R3 Memory Modules Replacement, Spreading Apart the Clips: 步骤 2 中的图像 3,3
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector un til the memory module pops up.
  3. Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Module: 步骤 3 中的图像 1,2 Dell Alienware M17x R3 Memory Modules Replacement, Removing the Memory Module: 步骤 3 中的图像 2,2
    • Remove the memory module from the memory-module connector.
  4. Dell Alienware M17x R3 Memory Modules Replacement, Align the Notch: 步骤 4 中的图像 1,1
    • If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  5. Dell Alienware M17x R3 Memory Modules Replacement, Installing the Memory Module: 步骤 5 中的图像 1,1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
结论
Terrence15
于12/18/17注册
79,309 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,984篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 533
