跳转到主内容
Dell Alienware M17x R2 Memory Modules Replacement
你所需要的
  1. Dell Alienware M17x R2 Memory Modules Replacement, Loosen the Screw: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Loosen the captive screw that secures the memory-module door to the computer base.
  2. Dell Alienware M17x R2 Memory Modules Replacement, Sliding the Memory Module Door: 步骤 2 中的图像 1,1
    • Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
  3. Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: 步骤 3 中的图像 1,3 Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: 步骤 3 中的图像 2,3 Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: 步骤 3 中的图像 3,3
    • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
    • Use your fingertips to carefully spread apart the spring-locks on the memory module connector until the module pops up.
  4. Dell Alienware M17x R2 Memory Modules Replacement, Removing the Memory Module: 步骤 4 中的图像 1,1
    • Remove the memory module.
  5. Dell Alienware M17x R2 Memory Modules Replacement, Align the Notch: 步骤 5 中的图像 1,2 Dell Alienware M17x R2 Memory Modules Replacement, Align the Notch: 步骤 5 中的图像 2,2
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch on the NEW memory module with the tab on the memory module connector.
  6. Dell Alienware M17x R2 Memory Modules Replacement, Inserting the Memory Module: 步骤 6 中的图像 1,2 Dell Alienware M17x R2 Memory Modules Replacement, Inserting the Memory Module: 步骤 6 中的图像 2,2
    • Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
    • CAUTION: If the memory module door is difficult to close, remove the memory module and reinstall it. Forcing the memory module door to close may damage your computer.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
结论
Terrence15
于12/18/17注册
79,858 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,993篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 826
