跳转到主内容
Dell Alienware M17x R2 Battery Pack Replacement
  1. Dell Alienware M17x R2 Battery Pack Replacement, Turn the Computer Over: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: Before performing these procedures, turn off the computer, disconnect the AC adapter from the electrical outlet and the computer, disconnect the modem from the wall connector and the computer, and remove any other external cables from the computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Turn the computer over.
  2. Dell Alienware M17x R2 Battery Pack Replacement, Slide the Battery Latch: 步骤 2 中的图像 1,1
    • Slide the battery latch to the unlock position as shown.
  3. Dell Alienware M17x R2 Battery Pack Replacement, Popping out the Battery Pack: 步骤 3 中的图像 1,1
    • The battery pack will pop up.
  4. Dell Alienware M17x R2 Battery Pack Replacement, Removing the Battery Pack: 步骤 4 中的图像 1,1
    • Remove the battery pack.
  5. Dell Alienware M17x R2 Battery Pack Replacement, Aligning the Battery Pack Tabs: 步骤 5 中的图像 1,1
    • Align the battery pack tabs with the slots in the battery bay.
  6. Dell Alienware M17x R2 Battery Pack Replacement, Sliding the Battery Pack: 步骤 6 中的图像 1,2 Dell Alienware M17x R2 Battery Pack Replacement, Sliding the Battery Pack: 步骤 6 中的图像 2,2
    • Slide the battery pack into the battery bay until the battery pack clicks into place.
结论
Terrence15
于12/18/17注册
79,243 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,480
