跳转到主内容
Dell Alienware M11x R3 Wi-Fi Card Replacement
你所需要的
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: 步骤 1 中的图像 1,3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: 步骤 1 中的图像 2,3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: 步骤 1 中的图像 3,3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 2 中的图像 1,2 Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 2 中的图像 2,2
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Dell Alienware M11x R3 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
结论
Richard Maurice
于03/08/17注册
534 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 754
