跳转到主内容
Dell Alienware M11x R3 Battery Replacement
你所需要的
  1. Dell Alienware M11x R3 Battery Replacement, Lower Case: 步骤 1 中的图像 1,3 Dell Alienware M11x R3 Battery Replacement, Lower Case: 步骤 1 中的图像 2,3 Dell Alienware M11x R3 Battery Replacement, Lower Case: 步骤 1 中的图像 3,3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Ensure your Dell Alienware M11x R3 is turned off and disconnected from any power source. Close the lid and flip the laptop over to access the bottom panel.
  3. Dell Alienware M11x R3 Battery Replacement: 步骤 3 中的图像 1,1
    • Caution: Ensure computer is completely powered down before attempting to remove the lower case of the computer.
    • Close the lid and flip the laptop over to access the bottom panel. Unscrew the two circled screws.
  4. Dell Alienware M11x R3 Battery Replacement: 步骤 4 中的图像 1,1
    • After removing the two screws, gently lift up the battery with the small plastic tab attached.
  5. Dell Alienware M11x R3 Battery Replacement: 步骤 5 中的图像 1,1
    • Caution: Do not attempt to fully remove the battery while the wire is still connected.
    • Lift the battery out of its casing while allowing the wire to remain attached.
  6. Dell Alienware M11x R3 Battery Replacement: 步骤 6 中的图像 1,1
    • Behind the battery, locate the PD12 battery wire and gently unplug it.
  7. Dell Alienware M11x R3 Battery Replacement: 步骤 7 中的图像 1,1
    • With the wire unplugged, and all of the screws taken out, you are free to remove the battery for replacement.
    • Remember to properly dispose of the old battery according to local regulations and recycling guidelines.
结论
To reassemble your device, follow these instructions in reverse order using a new battery in place of the old one.
2等其他人完成本指南。
Richard Maurice
于03/08/17注册
534 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 2,158
