跳转到主内容
Dell Alienware M11x R3 2.5" Hard Drive Replacement
你所需要的
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: 步骤 1 中的图像 1,3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: 步骤 1 中的图像 2,3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: 步骤 1 中的图像 3,3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,1
    • Remove the three screws attaching the hard drive tray to the laptop.
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 4 中的图像 2,2
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
结论
另外一个人完成了本指南。
Richard Maurice
于03/08/17注册
534 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,532
