跳转到主内容
加入维修社区 - 创建账户
Dell Alienware 18 Hard Drive Replacement
你所需要的
  1. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Disconnect the hard-drive cable from its connector on the system board.
  2. Dell Alienware 18 Hard Drive Replacement, Loosen the Screws: 步骤 2 中的图像 1,1
    • Loosen the captive screws that secure the hard-drive assembly to the computer base.
  3. Dell Alienware 18 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 3 中的图像 1,1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: 步骤 4 中的图像 1,2 Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: 步骤 4 中的图像 2,2
    • Disconnect the interposer from the hard drives.
    • NOTE: Your computer supports up to three drives.
  5. Dell Alienware 18 Hard Drive Replacement, Remove the Screws: 步骤 5 中的图像 1,1
    • Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
  6. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive: 步骤 6 中的图像 1,1
    • Place the NEW primary hard drive in the hard-drive bracket.
  7. Dell Alienware 18 Hard Drive Replacement, Sliding the Secondary Hard-Drive: 步骤 7 中的图像 1,1
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  8. Dell Alienware 18 Hard Drive Replacement, Secure the Screws: 步骤 8 中的图像 1,1
    • Replace the screws that secure the primary hard drive to the hard-drive bracket.
  9. Dell Alienware 18 Hard Drive Replacement, Replace the Screws: 步骤 9 中的图像 1,1
    • If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
  10. Dell Alienware 18 Hard Drive Replacement, Connecting the Interposer: 步骤 10 中的图像 1,1
    • Connect the interposer to the hard drives.
  11. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive Assembly: 步骤 11 中的图像 1,1
    • Place the hard-drive assembly in the computer base.
  12. Dell Alienware 18 Hard Drive Replacement, Tightening the Screws: 步骤 12 中的图像 1,1
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  13. Dell Alienware 18 Hard Drive Replacement, Connecting the Hard-Drive: 步骤 13 中的图像 1,1
    • Connect the hard-drive cable to its connector on the system board.
终点
2等其他人完成本指南。
darrius
于03/26/18注册
5,213 声望
创作了30篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了1,998篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 51
总计 1,253
