跳转到主内容
加入维修社区 - 创建账户
Dell Alienware 18 Display Assembly Replacement
你所需要的
  1. Dell Alienware 18 Display Assembly Replacement, Closing the Display: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin
    • Close the display and turn the computer over.
  2. Dell Alienware 18 Display Assembly Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the screws that secure the display assembly to the computer base.
  3. Dell Alienware 18 Display Assembly Replacement, Open the Display: 步骤 3 中的图像 1,1
    • Turn the computer over and open the display.
  4. Dell Alienware 18 Display Assembly Replacement, Disconnecting the Video-Card Connector: 步骤 4 中的图像 1,1
    • Disconnect the video-card connector cable from its connector on the system board.
  5. Dell Alienware 18 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 5 中的图像 1,1
    • Pull the pull-tab to disconnect the display cable from its connector on the system board.
  6. Dell Alienware 18 Display Assembly Replacement, Disconnecting the LED-Logo Board Cable: 步骤 6 中的图像 1,1
    • Disconnect the LED-logo board cable from its connector on the system board.
  7. Dell Alienware 18 Display Assembly Replacement, Disconnecting the Antenna Cables: 步骤 7 中的图像 1,1
  8. Dell Alienware 18 Display Assembly Replacement, Removing the Cables: 步骤 8 中的图像 1,1
    • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
  9. Dell Alienware 18 Display Assembly Replacement, Remove the Screws: 步骤 9 中的图像 1,1
    • Remove the screw that secures the routing guides to the computer base.
  10. Dell Alienware 18 Display Assembly Replacement, Lifting the Routing Guides: 步骤 10 中的图像 1,1
    • Slide and lift the routing guides off the computer base.
  11. Dell Alienware 18 Display Assembly Replacement, Remove the Screws: 步骤 11 中的图像 1,1
    • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
  12. Dell Alienware 18 Display Assembly Replacement, Lifting the Display Assembly: 步骤 12 中的图像 1,1
    • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
  13. Dell Alienware 18 Display Assembly Replacement, Placing the Display Assembly: 步骤 13 中的图像 1,1
    • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
  14. Dell Alienware 18 Display Assembly Replacement, Replace the Screw: 步骤 14 中的图像 1,1
    • Place the routing guides on the computer base and replace the screw that secures the routing guides to the computer base.
  15. Dell Alienware 18 Display Assembly Replacement, Route the Mini-card: 步骤 15 中的图像 1,1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  16. Dell Alienware 18 Display Assembly Replacement, Connecting the Display Cable: 步骤 16 中的图像 1,1
    • Connect the Mini-Card antenna cables to the Mini-Card. See"Replacing the Wireless Mini-Card" on page 107.
    • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
  17. Dell Alienware 18 Display Assembly Replacement, Close the Display: 步骤 17 中的图像 1,1
  18. Dell Alienware 18 Display Assembly Replacement, Replace the Screws: 步骤 18 中的图像 1,1
    • Replace the screws that secure the display assembly to the computer base.
终点
另外一个人完成了本指南。
darrius
于03/26/18注册
5,213 声望
创作了30篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了1,998篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 53
总计 1,125
