跳转到主内容
Dell Alienware 15 R3 Wi-Fi Card Replacement
你所需要的
  1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: 步骤 1 中的图像 1,3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: 步骤 1 中的图像 2,3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: 步骤 1 中的图像 3,3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Wi-Fi Card Replacement, Cover Assembly: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Dell Alienware 15 R3 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Wi-Fi Card Replacement: 步骤 5 中的图像 1,3 Dell Alienware 15 R3 Wi-Fi Card Replacement: 步骤 5 中的图像 2,3 Dell Alienware 15 R3 Wi-Fi Card Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 1,3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 2,3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 6 中的图像 3,3
    • Open the flap to reveal the Wi-Fi card.
    • Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
    • Use a spudger to detach the coaxial cables from the Wi-Fi card.
    • Be careful when detaching these cable connectors from the Wi-Fi card. The base of the connectors are prone to break off.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 30
总计 338
