跳转到主内容
Dell Alienware 15 R3 RAM Replacement
你所需要的
  1. Dell Alienware 15 R3 RAM Replacement, Back Case: 步骤 1 中的图像 1,3 Dell Alienware 15 R3 RAM Replacement, Back Case: 步骤 1 中的图像 2,3 Dell Alienware 15 R3 RAM Replacement, Back Case: 步骤 1 中的图像 3,3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 RAM Replacement: 步骤 2 中的图像 1,1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • To remove the old RAM sticks, push the metal arms out to the side, using an opening tool or your fingers.
    • Slide the RAM stick out at a 45 degree angle.
    • The RAM sticks are not pictured in this device.
    • To place the new RAM stick, insert it at a 45 degree angle and push it down gently. The metal sides will latch if they are in the correct position.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 147
