简介
This guide will show you how to both remove and replace the battery of your Dell Alienware 15 R3 laptop.
你所需要的
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
另外一个人完成了本指南。
