简介
Use this guide to remove the back case from your Dell Alienware 15 R3. If the back case is damaged or you need to access the internals of your laptop, follow this guide to remove the back case.
Before beginning this repair, turn off the laptop and unplug the charging cord.
你所需要的
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
即将完成!
结论
