跳转到主内容
Dell Alienware 15 R3 Back Case Replacement
你所需要的
  1. Dell Alienware 15 R3 Back Case Replacement, Back Case: 步骤 1 中的图像 1,3 Dell Alienware 15 R3 Back Case Replacement, Back Case: 步骤 1 中的图像 2,3 Dell Alienware 15 R3 Back Case Replacement, Back Case: 步骤 1 中的图像 3,3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Back Case Replacement: 步骤 2 中的图像 1,1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 199
