跳转到主内容
Dell Alienware 13 Solid-State Drive (SSD) Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  1. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Pull Tab: 步骤 2 中的图像 1,1
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  2. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Disconnecting the State Drive: 步骤 3 中的图像 1,1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  3. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Remove Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  4. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: 步骤 5 中的图像 1,2 Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: 步骤 5 中的图像 2,2
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  5. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Slide and Lift: 步骤 6 中的图像 1,1
    • Slide and lift the solid-state drive off the solid-state assembly.
  6. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing the Solid-State Drive: 步骤 7 中的图像 1,1
    • Slide the new solid-state drive into the solid-state drive assembly.
  7. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replace the Screw: 步骤 8 中的图像 1,1
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  8. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Align: 步骤 9 中的图像 1,1
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  9. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Replacement: 步骤 10 中的图像 1,1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  10. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Connecting the Drive: 步骤 11 中的图像 1,1
    • Connect the solid-state drive cable to the system board.
  11. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Aligning Screws: 步骤 12 中的图像 1,1
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  12. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing Screws: 步骤 13 中的图像 1,1
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
终点
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
一条评论
Hi there. Could I have a link to the full service manual you got this from? Thanks.
Aiden - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 189
