跳转到主内容
Dell Alienware 13 R3 Solid-State Drive Replacement
你所需要的
  1. Dell Alienware 13 R3 Solid-State Drive Replacement, Loosen the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Solid-State Drive Replacement, Pry the Base Cover: 步骤 2 中的图像 1,1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Solid-State Drive Replacement, Lift the Base Cover: 步骤 3 中的图像 1,1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Solid-State Drive Replacement, Disconnect the Battery Cable: 步骤 4 中的图像 1,1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Solid-State Drive Replacement, Slide the Tabs: 步骤 7 中的图像 1,1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Solid-State Drive Replacement, Tighten the Five Captive Screws: 步骤 8 中的图像 1,1
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Solid-State Drive Replacement, Remove the Screw: 步骤 9 中的图像 1,1
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  8. Dell Alienware 13 R3 Solid-State Drive Replacement, Lift and Slide the Solid-State Drive: 步骤 10 中的图像 1,1
    • Lift and slide the solid-state drive from the solid-state drive slot.
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
  9. Dell Alienware 13 R3 Solid-State Drive Replacement, Press the Memory Module: 步骤 12 中的图像 1,1
    • Press the memory module down until it clicks into place.
结论
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 492
