跳转到主内容
Dell Alienware 13 R2 Solid-State Drive Replacement
你所需要的
  1. Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Screws: 步骤 1 中的图像 1,2 Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Screws: 步骤 1 中的图像 2,2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  2. Dell Alienware 13 R2 Solid-State Drive Replacement, Peel off Computer Base Tabs: 步骤 2 中的图像 1,2 Dell Alienware 13 R2 Solid-State Drive Replacement, Peel off Computer Base Tabs: 步骤 2 中的图像 2,2
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  3. Dell Alienware 13 R2 Solid-State Drive Replacement, Disconnecting the Solid-State Drive Cable: 步骤 3 中的图像 1,1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  4. Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Solid-State Drive: 步骤 4 中的图像 1,2 Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Solid-State Drive: 步骤 4 中的图像 2,2
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  5. Dell Alienware 13 R2 Solid-State Drive Replacement, Lifting the Solid-State Assembly: 步骤 5 中的图像 1,1
    • Lift the solid-state drive assembly off the computer base.
  6. Dell Alienware 13 R2 Solid-State Drive Replacement, Remove the Screw: 步骤 6 中的图像 1,1
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  7. Dell Alienware 13 R2 Solid-State Drive Replacement, Lift the Solid-State Assembly.: 步骤 7 中的图像 1,2 Dell Alienware 13 R2 Solid-State Drive Replacement, Lift the Solid-State Assembly.: 步骤 7 中的图像 2,2
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  8. Dell Alienware 13 R2 Solid-State Drive Replacement, The New Solid-State Drive: 步骤 8 中的图像 1,1
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  9. Dell Alienware 13 R2 Solid-State Drive Replacement, Screw Replacement: 步骤 9 中的图像 1,2 Dell Alienware 13 R2 Solid-State Drive Replacement, Screw Replacement: 步骤 9 中的图像 2,2
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  10. Dell Alienware 13 R2 Solid-State Drive Replacement, Align the Screws: 步骤 10 中的图像 1,2 Dell Alienware 13 R2 Solid-State Drive Replacement, Align the Screws: 步骤 10 中的图像 2,2
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  11. Dell Alienware 13 R2 Solid-State Drive Replacement, Replace the Screws: 步骤 11 中的图像 1,1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Solid-State Drive Replacement, Connect the Cable to the System Board: 步骤 12 中的图像 1,1
    • Connect the solid-state drive cable to the system board.
  13. Dell Alienware 13 R2 Solid-State Drive Replacement, Align the Screw Holes: 步骤 13 中的图像 1,1
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  14. Dell Alienware 13 R2 Solid-State Drive Replacement, Replace the Screws: 步骤 14 中的图像 1,2 Dell Alienware 13 R2 Solid-State Drive Replacement, Replace the Screws: 步骤 14 中的图像 2,2
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
结论
Terrence15
于12/18/17注册
79,309 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,984篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 272
