跳转到主内容
Dell Alienware 13 R2 Heat-Sink Assembly Replacement
你所需要的
  1. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Turning Over the PC: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer After working inside your computer, follow the instructions in After Working Inside Your Computer For more safety best practices, see the regulatory compliance home page.
    • Close the display and turn the computer over.
  2. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Loosen the screws: 步骤 2 中的图像 1,1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Releasing the Tabs: 步骤 3 中的图像 1,1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Battery Cable: 步骤 4 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Battery Cable: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the battery-cable connector.
    • Turn the computer over.
  5. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Power Button: 步骤 5 中的图像 1,1
    • Press and hold the power button for 5 seconds to ground the system board.
    • Connect the battery cable to the battery-cable connector.
  6. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Aligning the tabs: 步骤 7 中的图像 1,1
    • Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
  7. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Tighten the screws: 步骤 8 中的图像 1,1
    • Tighten the captive screws that secure the base panel to the computer base.
  8. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Screws: 步骤 9 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Screws: 步骤 9 中的图像 2,2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  9. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Peel off Computer Base Tabs: 步骤 10 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Peel off Computer Base Tabs: 步骤 10 中的图像 2,2
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  10. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Solid-State Drive Cable: 步骤 11 中的图像 1,1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  11. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Solid-State Drive: 步骤 12 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Solid-State Drive: 步骤 12 中的图像 2,2
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Solid-State Assembly: 步骤 13 中的图像 1,1
    • Lift the solid-state drive assembly off the computer base.
  13. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: 步骤 14 中的图像 1,1
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  14. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Solid-State Assembly.: 步骤 15 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Solid-State Assembly.: 步骤 15 中的图像 2,2
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  15. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, The New Solid-State Drive: 步骤 16 中的图像 1,1
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  16. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Screw Replacement: 步骤 17 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Screw Replacement: 步骤 17 中的图像 2,2
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  17. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screws: 步骤 18 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screws: 步骤 18 中的图像 2,2
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  18. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: 步骤 19 中的图像 1,1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  19. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Connect the Cable to the System Board: 步骤 20 中的图像 1,1
    • Connect the solid-state drive cable to the system board.
  20. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: 步骤 21 中的图像 1,1
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  21. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: 步骤 22 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: 步骤 22 中的图像 2,2
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  22. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Latches: 步骤 23 中的图像 1,1
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
  23. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: 步骤 24 中的图像 1,1
    • Remove the screws that secure the palm-rest assembly to the computer base.
  24. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Computer Base: 步骤 25 中的图像 1,1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
    • Turn the computer over and open the display as far as possible.
  25. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Prying the Palm-Rest Assembly: 步骤 27 中的图像 1,1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  26. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Palm-Rest Assembly: 步骤 28 中的图像 1,1
    • Gently lift the palm-rest assembly and turn it over.
  27. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Connector Latch: 步骤 29 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Connector Latch: 步骤 29 中的图像 2,2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
  28. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Palm-Rest Assembly: 步骤 30 中的图像 1,1
    • Lift the palm-rest assembly off the computer base.
  29. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing: 步骤 31 中的图像 1,1
    • Remove the keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the Touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
    • Connect the power-button board cable to the system board.
  30. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Palm-Rest Assembly: 步骤 34 中的图像 1,1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  31. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: 步骤 39 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: 步骤 39 中的图像 2,2
    • Remove the screws that secure the hinge caps to the display hinges.
  32. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Hinge Caps: 步骤 40 中的图像 1,1
    • Slide and lift the hinge caps off the display hinges.
  33. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: 步骤 42 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: 步骤 42 中的图像 2,2
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  34. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Antenna Cables: 步骤 43 中的图像 1,1
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  35. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Antenna Cables: 步骤 45 中的图像 1,1
    • Remove the antenna cables from the routing guides on the display hinges.
  36. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Display Cable: 步骤 46 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Display Cable: 步骤 46 中的图像 2,2
    • Lift the connector latch and disconnect the display cable from the system board.
  37. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Display Cable: 步骤 47 中的图像 1,2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Display Cable: 步骤 47 中的图像 2,2
    • Remove the display cable from the routing guides on the display hinges.
  38. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Logo-Board Cable: 步骤 48 中的图像 1,1
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  39. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: 步骤 49 中的图像 1,1
    • Remove the screws that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  40. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: 步骤 51 中的图像 1,1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  41. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: 步骤 52 中的图像 1,1
    • Replace the screws that secure the display hinges to the computer base.
  42. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Routing the Logo-Board Cable: 步骤 53 中的图像 1,1
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  43. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Route the Cable: 步骤 54 中的图像 1,1
    • Route the display cable through the routing guides on the display hinge.
  44. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Slide the Display Cable: 步骤 55 中的图像 1,1
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
    • Route the antenna cables through the routing guides on the display hinges.
  45. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Adhere the Adhesive Tapes: 步骤 57 中的图像 1,1
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
    • Connect the antenna cables to the wireless card.
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  46. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: 步骤 62 中的图像 1,1
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
  47. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: 步骤 64 中的图像 1,1
    • Remove the screw that secures the power-adapter port bracket to the power-adapter port.
  48. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Power-Adapter: 步骤 65 中的图像 1,1
    • Lift the power-adapter port bracket off the power-adapter port.
    • Release the power-adapter port from the computer base.
  49. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Speaker Cable: 步骤 67 中的图像 1,1
    • Disconnect the speaker cable from the system board.
  50. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: 步骤 68 中的图像 1,1
    • Remove the screws that secure the system board to the computer base.
  51. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the System Board Assembly: 步骤 69 中的图像 1,1
    • Slide and lift the system-board assembly.
    • Turn the system-board assembly over.
  52. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Power-Adapter Port: 步骤 71 中的图像 1,1
    • Disconnect the power-adapter port cable and remove the power-adapter port from the system board.
    • Connect the power-adapter port cable to the system board.
    • Turn the system board over.
  53. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: 步骤 74 中的图像 1,1
    • Replace the screws that secure the system board to the computer base.
  54. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Connecting the Speaker Cable: 步骤 75 中的图像 1,1
    • Connect the speaker cable to the connector on the system board.
    • Align the power-adapter port to the computer base.
  55. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Hole: 步骤 77 中的图像 1,1
    • Align the screw hole on the power-adapter port bracket with the screw hole on the power-adapter port.
    • Replace the screw that secures the power-adapter port bracket to the power-adapter port.
  56. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Fan Cables: 步骤 79 中的图像 1,1
  57. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: 步骤 81 中的图像 1,1
    • Remove the screws that secure the heat-sink assembly to the system board.
  58. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Heat-Sink Assembly: 步骤 82 中的图像 1,1
    • Lift the heat-sink assembly off the system board.
  59. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: 步骤 83 中的图像 1,1
    • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
    • Replace the screws that secure the heat-sink assembly to the system board.
  60. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Connect the fan Cables: 步骤 86 中的图像 1,1
    • Connect the fan cables to the connectors on the system board.
结论
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 337
