跳转到主内容
Dell Adamo 13 Keyboard Replacement
你所需要的
  1. Dell Adamo 13 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
  4. Dell Adamo 13 Keyboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove six 2 mm screws securing the fan and motherboard to the device.
  5. Dell Adamo 13 Keyboard Replacement: 步骤 5 中的图像 1,3 Dell Adamo 13 Keyboard Replacement: 步骤 5 中的图像 2,3 Dell Adamo 13 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Remove all the connections to the circuit board on top and underneath.
    • Use caution when removing connections to prevent damage.
    • Remove the motherboard from the device.
  6. Dell Adamo 13 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove eight 2 mm screws securing the keypad to the device.
  7. Dell Adamo 13 Keyboard Replacement: 步骤 7 中的图像 1,2 Dell Adamo 13 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Gently lift the keypad out of the laptop mainframe.
结论
Tyler Pourmand
于10/25/21注册
85 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G7
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 12
总计 175
