简介
The rear panel is the end of the Dell AC511 speaker the USB cable protrudes from. Replacing the rear panel may lead to an increased product life expectancy if sufficiently damaged, though it will mostly lead to a better look overall rather than better functionality unless unwanted buzzing occurs.
你所需要的
Use a Jimmy to peel off the screen stuck to the front of the speaker.
Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
Follow the three wires connected to the speaker to find where they connect to the circuit board.
Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
Apply a light downward pressure on the circuit board next to the volume control.
While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
Use the pointy end of the spudger to push the audio jack ports into the device to disconnect the secondary circuit board from the rear ranel.
