跳转到主内容
Dell 3100 (Touch) Battery Replacement
  1. Dell 3100 (Touch) Battery Replacement, Detach Bottom Cover: 步骤 1 中的图像 1,2 Dell 3100 (Touch) Battery Replacement, Detach Bottom Cover: 步骤 1 中的图像 2,2
    • Unscrew the nine PH#0 captive screws on the bottom of the device.
    • Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
  2. Dell 3100 (Touch) Battery Replacement, Unplug the battery: 步骤 2 中的图像 1,2 Dell 3100 (Touch) Battery Replacement, Unplug the battery: 步骤 2 中的图像 2,2
    • Pull carefully, but firmly, on the battery cable until it becomes detached.
  3. Dell 3100 (Touch) Battery Replacement, Remove the battery: 步骤 3 中的图像 1,1
    • Remove these three M2x5 screws and take the battery out
    • If your replacement battery doesn't come with a cable, you will need to remove the cable from the old battery before disposing of it.
    • DO NOT throw batteries in the trash. Take them to a proper battery recycling center.
  4. Dell 3100 (Touch) Battery Replacement, Battery: 步骤 4 中的图像 1,2 Dell 3100 (Touch) Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Use a plastic spudger to lift up the flap. Use the flap to pull the connector straight away from the board (towards the battery).
  5. Dell 3100 (Touch) Battery Replacement: 步骤 5 中的图像 1,1
    • Remove 3 M2x4 screws
  6. Dell 3100 (Touch) Battery Replacement: 步骤 6 中的图像 1,3 Dell 3100 (Touch) Battery Replacement: 步骤 6 中的图像 2,3 Dell 3100 (Touch) Battery Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to detach the tab, and pull the tab up away from the device. This will break the adhesive holding in the battery.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 122
