跳转到主内容
Dell 1907FPc Monitor Power Supply Replacement
你所需要的
  1. Dell 1907FPc Monitor Power Supply Replacement, Power Supply: 步骤 1 中的图像 1,1
    • Carefully place the monitor face down on a flat surface, being careful to protect the display.
    • Remove the four 10 mm Phillips #2 screws from the back panel.
  2. Dell 1907FPc Monitor Power Supply Replacement: 步骤 2 中的图像 1,1
    • Flip the monitor back over, so that the display is facing you.
    • Use a spudger to remove the front bezel by unsnapping it in a counter clockwise fashion, starting at the bottom right, and ending at the button panel.
  3. Dell 1907FPc Monitor Power Supply Replacement: 步骤 3 中的图像 1,1
    • Slowly unsnap the bezel around the buttons.
    • Be careful to not fully remove the bezel here, because a ribbon cable attaches the buttons to the monitor.
  4. Dell 1907FPc Monitor Power Supply Replacement: 步骤 4 中的图像 1,1
    • Carefully flip the monitor back over, making sure to keep the front bezel in place.
    • Lift the back cover off of the rest of the monitor.
  5. Dell 1907FPc Monitor Power Supply Replacement: 步骤 5 中的图像 1,3 Dell 1907FPc Monitor Power Supply Replacement: 步骤 5 中的图像 2,3 Dell 1907FPc Monitor Power Supply Replacement: 步骤 5 中的图像 3,3
    • Locate the USB port cover on the right hand side of the monitor.
    • Remove the one 5 mm Phillips #2 screw.
    • Remove the USB port cover by sliding it out and away from the monitor.
  6. Dell 1907FPc Monitor Power Supply Replacement: 步骤 6 中的图像 1,2 Dell 1907FPc Monitor Power Supply Replacement: 步骤 6 中的图像 2,2
    • Disconnect the USB ports by gentling grasping and pulling on the connector.
  7. Dell 1907FPc Monitor Power Supply Replacement: 步骤 7 中的图像 1,1
    • Remove the five 5 mm Phillips #2 screws from the back panel.
  8. Dell 1907FPc Monitor Power Supply Replacement: 步骤 8 中的图像 1,2 Dell 1907FPc Monitor Power Supply Replacement: 步骤 8 中的图像 2,2
    • Remove the four 4 mm Phillips #2 screws that secure the monitor mount release mechanism to the panel.
    • Set this mechanism off to the side, taking care to keep it all in one piece.
  9. Dell 1907FPc Monitor Power Supply Replacement: 步骤 9 中的图像 1,2 Dell 1907FPc Monitor Power Supply Replacement: 步骤 9 中的图像 2,2
    • Use a 5 mm nut driver to remove the four 12 mm standoff screws securing the video connectors to the panel.
  10. Dell 1907FPc Monitor Power Supply Replacement: 步骤 10 中的图像 1,2 Dell 1907FPc Monitor Power Supply Replacement: 步骤 10 中的图像 2,2
    • Use the tweezers to lift up the seven security tabs that secure the back panel to the rest of the monitor.
    • If the security tabs are held down too tightly, use the spudger to pry them up, and then finish them off with the tweezers.
  11. Dell 1907FPc Monitor Power Supply Replacement: 步骤 11 中的图像 1,3 Dell 1907FPc Monitor Power Supply Replacement: 步骤 11 中的图像 2,3 Dell 1907FPc Monitor Power Supply Replacement: 步骤 11 中的图像 3,3
    • Lift up on the back panel to remove it from the rest of the monitor.
    • Be careful when doing so, as the edges of the back panel can be very sharp.
  12. Dell 1907FPc Monitor Power Supply Replacement: 步骤 12 中的图像 1,2 Dell 1907FPc Monitor Power Supply Replacement: 步骤 12 中的图像 2,2
    • The power supply has several large capacitors (they look like little cylinders), that can shock you if they discharge. Be careful not to touch them as you continue to work.
    • Use the tweezers to remove the four connectors from the power supply board.
  13. Dell 1907FPc Monitor Power Supply Replacement: 步骤 13 中的图像 1,1
    • Remove the five 7 mm Phillips #2 screws from the power supply board.
  14. Dell 1907FPc Monitor Power Supply Replacement: 步骤 14 中的图像 1,2 Dell 1907FPc Monitor Power Supply Replacement: 步骤 14 中的图像 2,2
    • Open up the clip securing the wires running between the power supply and video boards.
    • Gently remove the connector running from the video board to the power supply board.
  15. Dell 1907FPc Monitor Power Supply Replacement: 步骤 15 中的图像 1,2 Dell 1907FPc Monitor Power Supply Replacement: 步骤 15 中的图像 2,2
    • The power supply board can now be removed.
结论
8等其他人完成本指南。
Geoff Wacker
于09/30/13注册
89,934 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 6,211
