跳转到主内容
加入维修社区 - 创建账户
Dell 1350cnw WiFi Module Replacement
你所需要的
  1. Dell 1350cnw WiFi Module Replacement, Unclip front top band: 步骤 1 中的图像 1,2 Dell 1350cnw WiFi Module Replacement, Unclip front top band: 步骤 1 中的图像 2,2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Dell 1350cnw WiFi Module Replacement, Unclip front top band: 步骤 2 中的图像 1,2 Dell 1350cnw WiFi Module Replacement, Unclip front top band: 步骤 2 中的图像 2,2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Dell 1350cnw WiFi Module Replacement, Remove front top band: 步骤 3 中的图像 1,1
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Dell 1350cnw WiFi Module Replacement, Remove left-side top band: 步骤 4 中的图像 1,3 Dell 1350cnw WiFi Module Replacement, Remove left-side top band: 步骤 4 中的图像 2,3 Dell 1350cnw WiFi Module Replacement, Remove left-side top band: 步骤 4 中的图像 3,3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Dell 1350cnw WiFi Module Replacement, Remove control panel module: 步骤 5 中的图像 1,3 Dell 1350cnw WiFi Module Replacement, Remove control panel module: 步骤 5 中的图像 2,3 Dell 1350cnw WiFi Module Replacement, Remove control panel module: 步骤 5 中的图像 3,3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
  6. Dell 1350cnw WiFi Module Replacement, Remove front cover: 步骤 6 中的图像 1,1
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
  7. Dell 1350cnw WiFi Module Replacement, Remove front cover: 步骤 7 中的图像 1,1
    • Remove both 7mm phillips screws securing the front cover in place.
  8. Dell 1350cnw WiFi Module Replacement, Remove front cover: 步骤 8 中的图像 1,3 Dell 1350cnw WiFi Module Replacement, Remove front cover: 步骤 8 中的图像 2,3 Dell 1350cnw WiFi Module Replacement, Remove front cover: 步骤 8 中的图像 3,3
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
  9. Dell 1350cnw WiFi Module Replacement, Remove front cover: 步骤 9 中的图像 1,1
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
  10. Dell 1350cnw WiFi Module Replacement, Remove top cover: 步骤 10 中的图像 1,2 Dell 1350cnw WiFi Module Replacement, Remove top cover: 步骤 10 中的图像 2,2
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
  11. Dell 1350cnw WiFi Module Replacement, Remove top cover: 步骤 11 中的图像 1,2 Dell 1350cnw WiFi Module Replacement, Remove top cover: 步骤 11 中的图像 2,2
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
  12. Dell 1350cnw WiFi Module Replacement, Remove top cover: 步骤 12 中的图像 1,1
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
  13. Dell 1350cnw WiFi Module Replacement, Remove top cover: 步骤 13 中的图像 1,1
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
  14. Dell 1350cnw WiFi Module Replacement, Remove top cover: 步骤 14 中的图像 1,1
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
  15. Dell 1350cnw WiFi Module Replacement, Remove side cover: 步骤 15 中的图像 1,3 Dell 1350cnw WiFi Module Replacement, Remove side cover: 步骤 15 中的图像 2,3 Dell 1350cnw WiFi Module Replacement, Remove side cover: 步骤 15 中的图像 3,3
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
  16. Dell 1350cnw WiFi Module Replacement, Unplug WiFi module: 步骤 16 中的图像 1,1
    • Pull out the WiFi module plug from the USB/Ethernet board to disconnect.
  17. Dell 1350cnw WiFi Module Replacement, Remove WiFi module: 步骤 17 中的图像 1,2 Dell 1350cnw WiFi Module Replacement, Remove WiFi module: 步骤 17 中的图像 2,2
    • Unscrew the 7mm phillips screw holding the WiFi module to the printer and remove the WiFi module.
结论
Jac
于10/08/24注册
2,728 声望
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 11
总计 58
