跳转到主内容
Dell 5558 - 574J362 Disassembly
你所需要的
  1. Dell  5558 -  574J362  Disassembly, Removing the battery: 步骤 1 中的图像 1,1
    • Always remove the battery before working on any laptop.
  2. Dell  5558 -  574J362  Disassembly, Removing the keyboard: 步骤 2 中的图像 1,1
    • remove keyboard by prying up gently the tabs on the keyboard. First tab is shown.
  3. Dell  5558 -  574J362  Disassembly, Removing cables: 步骤 3 中的图像 1,2 Dell  5558 -  574J362  Disassembly, Removing cables: 步骤 3 中的图像 2,2
    • Remove the keyboard cable and other cables.
  4. Dell  5558 -  574J362  Disassembly, Removing other cables: 步骤 4 中的图像 1,1
    • To remove a cable lift up on the black tab. To reconnect stick the cable underneath the black tab and press down.
  5. Dell  5558 -  574J362  Disassembly, Removing the access panel: 步骤 5 中的图像 1,1
    •  Remove the 2 - M2.5 x 8mm screws.
  6. Dell  5558 -  574J362  Disassembly, Removing the optical Drive and base cover: 步骤 6 中的图像 1,1
    • Remove the 1- M2 x 5mm screw. Use the slot under the battery to slide the optical drive out. Remove the DVD Optical Drive.
    • Remove the screws from the back panel.
    • Close the display and turn the computer over. Remove the screws that secure the base cover to the computer base. Using your fingertips, pry the base cover starting at the top edge out of the computer base. Lift the base cover off the computer base.
  7. Dell  5558 -  574J362  Disassembly, Removing the Wi Fy card: 步骤 7 中的图像 1,1
    • Unhook the black and white wire from the MB shown in the lower circle. Remove the screw from the card shown in the upper circle.
  8. Dell  5558 -  574J362  Disassembly, Unplugging the speaker cable and unhooking the RAM: 步骤 8 中的图像 1,1
    • Unhook the speaker cable from the MB.
    • Ram slots are next to the speaker cable. If needed, take out the RAM by prying back the hindes on the RAM.
  9. Dell  5558 -  574J362  Disassembly, Removing the hinges: 步骤 9 中的图像 1,1
    • Remove the 2 - M2.5 x 8mm hinge screws.Remove the 4 - M2.5 x 5mm screws under the battery. Remove the 6 - M2.5 x 8mm screws under the access door.
  10. Dell  5558 -  574J362  Disassembly, Removing the display: 步骤 10 中的图像 1,1
    • Note the antenna cable routing and remove the cable from its routing guides. Lift the latch and disconnect the display cable from the system board.Turn the computer over. Open the display at an angle of 90 degrees.
    • Place the computer on the edge of the table so that the palm-rest assembly is on the table and the display assembly extends past the table edge with the display hinges facing up. Remove the screws that secure the display hinges to the palm-rest assembly.
  11. Dell  5558 -  574J362  Disassembly, Removing the hard drive: 步骤 11 中的图像 1,1
    • Remove the screws and detach the hard drive from the base. The hard drive will be in an enclosure and you will need to unscrew it from its enclosure.
  12. Dell  5558 -  574J362  Disassembly, Removing cables: 步骤 12 中的图像 1,1
    • Remove three cables under neath the keyboard. Hard drive cable is on the left.
结论
另外一个人完成了本指南。
Perry Mitchell
于02/21/17注册
452 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,701
