跳转到主内容
Dell Inspiron 15-7569 Motherboard Replacement
你所需要的
  1. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: 步骤 2 中的图像 1,3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: 步骤 2 中的图像 2,3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
    • Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
    • Remove the fan from the motherboard.
  3. Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 3 中的图像 1,3 Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 3 中的图像 2,3 Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires.
    • Remove the black speaker wire.
    • Remove the white display wire.
  4. Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 4 中的图像 1,3 Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 4 中的图像 2,3 Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 4 中的图像 3,3
    • (Continued)Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires
    • Remove the gold and silver display cables.
    • Remove the white fan cable.
    • Remove the USB-to-motherboard cable
  5. Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 5 中的图像 1,2 Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the black battery cable.
    • Remove the blue ribbon cable.
    • Unscrew and remove hard drive/SSD.
    • Disconnect the hard drive/SSD from the motherboard.
  6. Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 6 中的图像 1,2 Dell   Inspiron  15-7569 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Gently remove the motherboard from the device.
结论
团队
USF Tampa, Team S5-G4, Walkup Fall 2017 USF Tampa, Team S5-G4, Walkup Fall 2017 的会员
USFT-WALKUP-F17S5G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,560
