跳转到主内容
Dell Inspiron 15-7569 Battery Replacement
你所需要的
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: 步骤 2 中的图像 1,3 Dell   Inspiron  15-7569 Battery Replacement, Battery: 步骤 2 中的图像 2,3 Dell   Inspiron  15-7569 Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
结论
5等其他人完成本指南。
团队
USF Tampa, Team S5-G4, Walkup Fall 2017 USF Tampa, Team S5-G4, Walkup Fall 2017 的会员
USFT-WALKUP-F17S5G4
4 名成员
创作了6篇指南
一条评论
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 33
总计 6,251
