跳转到主内容
Definitive Technology W7 Motherboard Replacement
你所需要的
  1. Definitive Technology W7 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Definitive Technology W7 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Definitive Technology W7 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
    • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
    • Use the metal spudger to remove all rubber feet.
    • Unscrew all four screws from under the rubber feet.
    • These screws will be approximately 35 mm in length.
    • You can now use the prying tool to pry the bottom panel off the speaker.
  2. Definitive Technology W7 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
    • These screws are approximately 8 mm in length.
  3. Definitive Technology W7 Motherboard Replacement: 步骤 3 中的图像 1,2 Definitive Technology W7 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Push up the locking tabs on the sides of the ribbon cable connector.
    • Gently pull the ribbon cable out from the connector to remove it.
  4. Definitive Technology W7 Motherboard Replacement: 步骤 4 中的图像 1,2 Definitive Technology W7 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Tilt the motherboard outwards from the speaker.
    • Remove all five connectors from the motherboard.
    • Remove the motherboard from the speaker.
  5. Definitive Technology W7 Motherboard Replacement: 步骤 5 中的图像 1,2 Definitive Technology W7 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips #2 screwdriver, remove the three screws from the network card.
    • These screws are approximately 8mm in length.
    • Remove the network card from the motherboard.
结论
Magnus Maillet
于10/26/22注册
171 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-5, Petersen Fall 2022 UMass Dartmouth, Team 2-5, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G5
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 19
总计 567
