跳转到主内容
Definitive Technology W7 Access Panel Replacement
你所需要的
  1. Definitive Technology W7 Access Panel Replacement, Access Panel: 步骤 1 中的图像 1,1
    • Wedge the spudger in any of the four corners of the panel and apply downward pressure on the spudgers handle to pry the panel away from the speaker housing.
    • Repeat this procedure around the perimeter until the panel releases, then lift the panel up by hand.
  2. Definitive Technology W7 Access Panel Replacement: 步骤 2 中的图像 1,2 Definitive Technology W7 Access Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the thirteen 5 mm Phillips #0 screws.
    • Once all screws have been removed, gently pull up on the black panel to remove it from the top of the speaker.
  3. Definitive Technology W7 Access Panel Replacement: 步骤 3 中的图像 1,3 Definitive Technology W7 Access Panel Replacement: 步骤 3 中的图像 2,3 Definitive Technology W7 Access Panel Replacement: 步骤 3 中的图像 3,3
    • The gray mesh bag covering the speaker will now be exposed.
    • Flick the switch on the middle of the lock down to loosen the sack.
    • Pull upwards on the locking mechanism to loosen the drawstring. Stop pulling when the mesh bag is loose enough that it can be pulled downwards.
  4. Definitive Technology W7 Access Panel Replacement: 步骤 4 中的图像 1,2 Definitive Technology W7 Access Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
    • Remove the black panel.
结论
Brendan Thibault
于10/26/22注册
339 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-5, Petersen Fall 2022 UMass Dartmouth, Team 2-5, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G5
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 371
