跳转到主内容
Decorative Light Fixture Lightbulb Replacement
你所需要的
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: 步骤 1 中的图像 1,1
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: 步骤 2 中的图像 1,2 Decorative Light Fixture Lightbulb Replacement: 步骤 2 中的图像 2,2
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: 步骤 3 中的图像 1,1
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: 步骤 4 中的图像 1,2 Decorative Light Fixture Lightbulb Replacement: 步骤 4 中的图像 2,2
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: 步骤 5 中的图像 1,1
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: 步骤 6 中的图像 1,2 Decorative Light Fixture Lightbulb Replacement: 步骤 6 中的图像 2,2
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: 步骤 7 中的图像 1,2 Decorative Light Fixture Lightbulb Replacement: 步骤 7 中的图像 2,2
    • Hold onto the fixture, and screw it back in with the screwdriver.
终点
Jordan Parry
于03/30/21注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 27
总计 299
