简介
Tired of that annoying car badge that has been labeling you as the proud owner of an Accord? Maybe you think some neon pink flame stickers would look better where that shiny silver protrusion is? Use this guide to help you remove that badge so you can drive label free or install your own custom one!
你所需要的
Begin by thoroughly wetting the badge and surrounding area with soapy water.
Once the badge is fully wetted, wedge a strand of floss or fishing line between the car panel and the wedge.
Draw the floss back and forth in a sawing motion and simultaneously pull it along the badge until it detaches from the panel.
Use soapy water and the rough side of a sponge to remove the leftover adhesive. Other products such as Goo Gone or Goof Off are also excellent adhesive removers.
Fishing line works the best! Don't be discouraged if you see a shadow from the removed badge; it will fade and disappear with time. You have to figure the badge has been on the vehicle since it was manufacturered. Debadging your vehicle, gives it a clean, professional upper class look to it and its always funny to watch service techs try and figure out what make/model your vehicle is. No one has gotten it right yet. Corolla CE
21等其他人完成本指南。
5条评论
This thanks for this post, many of people have craze to use custom badge. This is good think you can get choice to use any of custom badge to stick on car with the Instant Adhesives.
I find ifixit's conclusion to be rather comical; To reassemble your device, follow these instructions in reverse order.
grumblerts - 回复
Rather than using an abrasive washing up sponge, try using a soft cloth with WD40. It will dissolve the remove the adhesive without risking damaging the paintwork.
