跳转到主内容
DeWalt DWE4011 Carbon Brushes Replacement
你所需要的
  1. DeWalt DWE4011 Carbon Brushes Replacement, Carbon Brushes: 步骤 1 中的图像 1,1
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Carbon Brushes Replacement: 步骤 2 中的图像 1,1
    • Remove the outer casing to expose the brushes by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Carbon Brushes Replacement: 步骤 3 中的图像 1,2 DeWalt DWE4011 Carbon Brushes Replacement: 步骤 3 中的图像 2,2
    • Locate both carbon brushes on either side of the device.
  4. DeWalt DWE4011 Carbon Brushes Replacement: 步骤 4 中的图像 1,1
    • Using the iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Carbon Brushes Replacement: 步骤 5 中的图像 1,1
    • Keeping a tight hold the entire time, move the spring covering the carbon brush so that it is behind the male terminal.
    • Be extremely careful, as the spring is tightly coiled and can easily get away from you.
  6. DeWalt DWE4011 Carbon Brushes Replacement: 步骤 6 中的图像 1,2 DeWalt DWE4011 Carbon Brushes Replacement: 步骤 6 中的图像 2,2
    • Taking hold of the wire you removed in step 4, gently slide the carbon brush out of its casing and remove it from the device.
    • Flip over the device to reveal the second carbon brush, and repeat steps 4 through 6 on the other side.
结论
Congratulations! To put your device back together, simply reverse the above steps.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 1,288
