跳转到主内容
DeWalt DW936 Trigger Replacement
你所需要的
  1. DeWalt DW936 Trigger Replacement, Plastic Cover: 步骤 1 中的图像 1,1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Trigger Replacement: 步骤 2 中的图像 1,1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Trigger Replacement: 步骤 3 中的图像 1,1
    • Remove Allen Key.
  4. DeWalt DW936 Trigger Replacement: 步骤 4 中的图像 1,1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Trigger Replacement: 步骤 5 中的图像 1,1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Trigger Replacement: 步骤 6 中的图像 1,1
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Trigger Replacement, Trigger: 步骤 7 中的图像 1,1
    • The trigger has black and white wires coming off of it. Grip the trigger with both hands, one on the plastic trigger part and the other on the plastic by the silver metal piece.
    • Pull up.
  8. DeWalt DW936 Trigger Replacement: 步骤 8 中的图像 1,1
    • The trigger should be able to sit freely.
  9. DeWalt DW936 Trigger Replacement: 步骤 9 中的图像 1,2 DeWalt DW936 Trigger Replacement: 步骤 9 中的图像 2,2
    • Lift off the silver metal piece using tweezers.
    • Lift off each hook. (4 corners)
  10. DeWalt DW936 Trigger Replacement: 步骤 10 中的图像 1,1
    • Pull plastic trigger out of the black plastic casing.
结论
2等其他人完成本指南。
Scott Weinhardt
于01/25/17注册
603 声望
创作了5篇指南
团队
Cal Poly, Team 8-2, Banghart Winter 2017 Cal Poly, Team 8-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G2
3 名成员
创作了5篇指南
一条评论
Then repair trigger by stripping,cleaning,soldering and whatever else before replacing to unit as you can no longer buy the part as it is obsolete!
donald.mcguinnes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 690
