跳转到主内容
DeWalt DW936 Saw Blade Replacement
  1. DeWalt DW936 Saw Blade Replacement, Saw Blade: 步骤 1 中的图像 1,1
    • Take out the Allen Key that is located on the front of the saw below the smooth control handle on the top of the saw.
  2. DeWalt DW936 Saw Blade Replacement: 步骤 2 中的图像 1,1
    • Use the Allen Key to replace to loosen the bolt where the center of the saw is/would be.
  3. DeWalt DW936 Saw Blade Replacement: 步骤 3 中的图像 1,1
    • Remove the circular nut that is used to hold the saw blade in place. It slide right off.
  4. DeWalt DW936 Saw Blade Replacement: 步骤 4 中的图像 1,1
    • Lift up the plastic cover on the bottom to expose the bottom slot on the saw.
  5. DeWalt DW936 Saw Blade Replacement: 步骤 5 中的图像 1,1
    • Place blade on the peg in the middle of the saw. The peg has two flat sides as does the saw hole to prevent slipping when spinning.
结论
2等其他人完成本指南。
Scott Weinhardt
于01/25/17注册
603 声望
创作了5篇指南
团队
Cal Poly, Team 8-2, Banghart Winter 2017 Cal Poly, Team 8-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 28
总计 2,901
