跳转到主内容
DeWalt DW936 Boot Replacement
你所需要的
  1. DeWalt DW936 Boot Replacement, Plastic Cover: 步骤 1 中的图像 1,1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Boot Replacement: 步骤 2 中的图像 1,1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Boot Replacement: 步骤 3 中的图像 1,1
    • Remove Allen Key.
  4. DeWalt DW936 Boot Replacement: 步骤 4 中的图像 1,1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Boot Replacement: 步骤 5 中的图像 1,1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Boot Replacement: 步骤 6 中的图像 1,1
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Boot Replacement, Boot: 步骤 7 中的图像 1,1
    • Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
  8. DeWalt DW936 Boot Replacement: 步骤 8 中的图像 1,1
    • Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
  9. DeWalt DW936 Boot Replacement: 步骤 9 中的图像 1,1
    • Pull the blade away from the body of the saw causing the blade and boot to detach.
  10. DeWalt DW936 Boot Replacement: 步骤 10 中的图像 1,1
    • Pull the boot downwards away from the blade to detach it.
结论
Scott Weinhardt
于01/25/17注册
603 声望
创作了5篇指南
团队
Cal Poly, Team 8-2, Banghart Winter 2017 Cal Poly, Team 8-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 474
