跳转到主内容
DeWalt DW920 Rotational Switch Replacement
你所需要的
  1. DeWalt DW920 Rotational Switch Replacement, Disassembly: 步骤 1 中的图像 1,1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Rotational Switch Replacement: 步骤 2 中的图像 1,1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Rotational Switch Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Rotational Switch Replacement, Rotational Switch: 步骤 4 中的图像 1,1
    • Locate the rotational switch
  5. DeWalt DW920 Rotational Switch Replacement: 步骤 5 中的图像 1,1
    • Carefully release the connection between the rotational switch and the motor assembly. This should be done carefully to ensure that the switch connection switch on the assembly is not damaged.
  6. DeWalt DW920 Rotational Switch Replacement: 步骤 6 中的图像 1,1
    • Once the switch is freed from the assembly, firmly grip it between two fingers and lift it straight out of the drill frame.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G2
2 名成员
创作了6篇指南
一条评论
Everything looks good on this guide, good job!
DankMemerino - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 1,373
