跳转到主内容
DeWalt DW920 Motor Replacement
你所需要的
  1. DeWalt DW920 Motor Replacement, Disassembly: 步骤 1 中的图像 1,1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: 步骤 2 中的图像 1,1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: 步骤 4 中的图像 1,1
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: 步骤 5 中的图像 1,1
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: 步骤 6 中的图像 1,1
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
结论
Stephen Rada
于03/11/16注册
433 声望
创作了4篇指南
团队
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G2
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 13
总计 805
