跳转到主内容
DeWalt DW920 Lock Switch Replacement
你所需要的
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: 步骤 1 中的图像 1,1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: 步骤 2 中的图像 1,1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: 步骤 4 中的图像 1,1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: 步骤 5 中的图像 1,2 DeWalt DW920 Lock Switch Replacement: 步骤 5 中的图像 2,2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
结论
Stephen Rada
于03/11/16注册
433 声望
创作了4篇指南
团队
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G2
2 名成员
创作了6篇指南
一条评论
This guide was descriptive and easy to follow. Good job!
DankMemerino - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 11
总计 271
