跳转到主内容
DeWalt DW660 Motor Brushes Replacement
你所需要的
  1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: 步骤 1 中的图像 1,2 DeWalt DW660 Motor Brushes Replacement, Motor Brushes: 步骤 1 中的图像 2,2
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. DeWalt DW660 Motor Brushes Replacement: 步骤 2 中的图像 1,3 DeWalt DW660 Motor Brushes Replacement: 步骤 2 中的图像 2,3 DeWalt DW660 Motor Brushes Replacement: 步骤 2 中的图像 3,3
    • Remove the other part of the back casing.
    • Unplug the black and white power wires from the motor.
  3. DeWalt DW660 Motor Brushes Replacement: 步骤 3 中的图像 1,2 DeWalt DW660 Motor Brushes Replacement: 步骤 3 中的图像 2,2
    • Pinch the blue brush wire between two fingers.
    • Pull on the wire, removing them from the motor.
  4. DeWalt DW660 Motor Brushes Replacement: 步骤 4 中的图像 1,2 DeWalt DW660 Motor Brushes Replacement: 步骤 4 中的图像 2,2
    • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
    • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
  5. DeWalt DW660 Motor Brushes Replacement: 步骤 5 中的图像 1,2 DeWalt DW660 Motor Brushes Replacement: 步骤 5 中的图像 2,2
    • Repeat steps 3 and 4 to remove the other carbon brush.
    • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
    • Refer to the photos for visual assistance.
结论
另外一个人完成了本指南。
Joseph Pacitto
于03/23/16注册
239 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-7, Isaacson Spring 2016 UMass Dartmouth, Team 2-7, Isaacson Spring 2016 的会员
UMASSD-ISAACSON-S16S2G7
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 16
总计 1,404
