简介
If your DeWalt Drill (DW235G) is acting a bit wonky due to old age or if you simply want to change the chuck to accommodate different bit sizes, then you are in the right place. The guide below details step-by-step how to dismantle the drill's existing chunk in order to replace the chuck component within the DeWalt Drill (DW235G). This guide includes a section in which a hammer or blunt object is used so use proper safety persuasions when executing the step.
你所需要的
Identify the Hex nut within the inside of the chuck of the drill.
Insert the 4mm Allen key into the chuck to loosen the Hex nut.
To actually install the chuck replacement part, follow the guide in reverse order.
另外一个人完成了本指南。
